Went to track. Need more power.
WC114
I spoke to spd. They said it was a 3rd party dyno. The numbers they quote are in the middle of all the dyno pulls so you may get more
10SpdsOfFury
Jacksonville FL
What I found works best is Sport mode 4A bring the RPMs up on the brake and you launch and hit second gear reach up and switch back to 2wd on the dial, at that point the front end drops back down and off you go.
butts182
Jupiter, FL
So what do you consider heat soaked? I ran 3 times back to back to back in FL and got faster ETs each time. My AIT was 140 when standing still, but drops when you accelerate. Not sure why everyone says they get “heat soaked”
WC114
What doesn't make sense. A 3rd party tested the spacer. They did baseline pulls on the dyno, then installed the spacer. Let's say they did 6 pulls , the power increased from a low of 20 on one pull to a high 25 on another pull. Spd used the lowest number 20 as their claimed power increase.
Truckzor
Would need more data to fully evaluate (specifically trap speeds and 60' times for each run).
reaper1441
I couldn't easily heat soak the stock intercooler at 23psi in 90* ambient temps in sand at speed. The stock intercooler works very well.
