Washing step prefect for Raptor
911 Crazy
Maine
I bought the Giantex platform on Amazon and am pleasantly surprised.
It is just the right height, making washing/drying hood, roof, front/rear glass much easier. The doors clear the step, so you don’t have to move to open
It is truly non-slip. Even when wet and soapy, I know I’m safe from slipping.
It is solid. I’m 240 lbs and there isn’t the slightest wobble or instability, made better with the four legs and their broad rubber bases.
Giantex Step Stool Folding Step... https://www.amazon.com/dp/B07RJJ7GKM/?tag=fordraptorforum-20
That looks like a great help. Just wish it had telescoping legs so maybe it could go up another 19" or so to get the roof.
CoronaRaptor
CANADA
Your Prius is only 19" tall,so what are you worried about? Wear some 70s platform shoes if you cant reach the middle of your prius roof!
Buzzard2
Sincity
So I got the Gorilla step stool from Home Depot and the Adam's step stool. I am no homer for Adam's products some I like some I don't but their step stool is in a different league than the HD Gorilla. The Adam's Is on Sale and $10.00 cheaper than the HD currently. I got a smoking deal on the HD stepper but really wish I had two Adam's units.
ljn21
Tega Cay, SC
Whats different between the two? Was looking at the HD Gorilla one for a second one.
melvimbe
At the basic level, the HD is more of a stepping stool while Adam's is more of platform.
Height -
HD - 3.5' ( 42")
Adam's - 20"? (A little hard to tell from description)
Adam's should be fine for use with the truck for most guys, but perhaps lacking for the wife?
Weight capacity -
HD - 250 lbs (fine for most)
Adams - 600 lbs (fine for all, and can fit two people)
Work surface width -
HD - 13"
Adam's - 38"?
This is a bigger factor than you think. With a standard step stool, I have to move the stool to 6 total locations to cover the entire roof and windows. Up/down gets annoying. If Adam's can reduce that to 2 that would be great. The design looks like I could reach over horizontally without risk of tipping over the stool.
Weight -
HD - 6.4 lbs
Adam's - 12.2 lbs.
Storage dimensions
HD - 13" x 42"X 3.25
Adam's - 12”x 38”x 8”
This can make a difference if you're tight on storage space. Also looks like you can easily hang HD on the wall easily. Adam's might be more of a challenge.
Cost -
HD - $30
Adam's - $60
It should be mentioned that HD has platforms similar to Adam's available, but nothing that looks to be of similar quality and price range.
ljn21
Tega Cay, SC
Height -
HD - 3.5' ( 42")
Weight capacity -
HD - 13"
Adam's - 38"?
Weight -
HD - 6.4 lbs
Adam's - 12.2 lbs.
Storage dimensions
Cost -
HD - $30
Adam's - $60
Awesome details, thanks!
Buzzard2
Sincity
Height -
HD - 3.5' ( 42")
Weight capacity -
HD - 13"
Adam's - 38"?
The Gorilla I have is not 42"
HD - 6.4 lbs
Adam's - 12.2 lbs.
Storage dimensions
Cost -
HD - $30
Adam's - $60
These size dimensions are different than the Gorilla I have. They are both comparable in dimensional size but not exact. The Gorilla does not have anti slip grip tape on the deck which I had to add. The Gorilla is just lighter and feels cheaper if that makes sense? The Adams has locking legs that are very simple, reliable and easy to use the gorilla has some spring loaded pins that I am already having trouble with one of them. I may see if I can return my Gorilla and get another Adam's.
I am in the cry once crowd.
