Yukon Joe
That's good news. keep you out of a yota and off the taco forum.called dealer today. they ordered a pcm, wire harness, starter, starter plate, and 4wd solenoid. apparently they found an open circuit in the 4wd solenoid motor. which has been the root cause of my 4wd issues. lets hope they are right. and to replace starter plate requires dropping the transmission. huh...... anyways, i asked questions regarding this solenoid and vacuum 4wd system. no hesitation to respond which tells me he has seen this before. good news to me i hope. they said to be safe they are ordering a wire harness as well as the pcm. even though they found the problem in the pcm, they want to be safe and replace the whole harness. they know im just about out of warranty and they seem to be doing everything they can to fix all my issues. so to fremont ford of riverton, i thank you for what you have done so far.
@Yukon Joe
Drive your raptor here!!!!
www.runraptorrun.com
( * Y * )
