warranty expiring and still 4wd problems
cpetes
DFW
Just came across this thread, sucks to hear Noah, hope they can sort things out for you.
The Car Stereo Company
here, on frf
Has your 4x4 EVER worked?
no. everytime i have tried to use it, it would always pop and disengage
---------- Post added at 05:30 PM ---------- Previous post was at 05:29 PM ----------
@Trick_Raptor why is there only pics of my truck and not yours?
WyoStorm
Wyoming
Now let's hope they get your 4 wheel drive system working! I told you that they would at least give it a go and be straight shooters.
Sent from my SM-G900V using Tapatalk
here, on frf
called dealer today. they ordered a pcm, wire harness, starter, starter plate, and 4wd solenoid. apparently they found an open circuit in the 4wd solenoid motor. which has been the root cause of my 4wd issues. lets hope they are right. and to replace starter plate requires dropping the transmission. huh...... anyways, i asked questions regarding this solenoid and vacuum 4wd system. no hesitation to respond which tells me he has seen this before. good news to me i hope. they said to be safe they are ordering a wire harness as well as the pcm. even though they found the problem in the pcm, they want to be safe and replace the whole harness. they know im just about out of warranty and they seem to be doing everything they can to fix all my issues. so to fremont ford of riverton, i thank you for what you have done so far.
96,364
60,271
tobychap
Latest posts
