Warning about rear window defrosters!!
KTM RAPTOR
Ontario, Canada
Whole assembly requires replacement unfortunately.
I wonder how bad things might get with the new design as one solid piece of glass across the back (sans center slider). Instead of just panels of glass being replaced, people will have to replace the whole rear window on the newer models... if shatter occurs.
The whole rear assembly has to come out even if one panel cracks/shatterson on these trucks.. Learned the hard way. Thankfully I was still under warranty at the time.
Sorry to burst your bubble GearTripper!
Mustangraptorkid
Woodbridge nj
Same thing happened to my 2010 I we'll be removing the wire to the button when the job is completed so no one is able to activate it I was given no explanation to why this keeps happening and I have done research and it has happened to standard f150 as Long as it's the three pieace window
KTM RAPTOR
Ontario, Canada
Another one bites the dust..
Another rear window down.. This time no defroster on, window still blows up.
Going to be an eventful day at the dealership this week! :ROFLJest:
All The Way
Lockport, NY
Mines finally blew up getting rid of morning dew
DeepSeaOne
NE FLorida
Just a suggestion but...pre-heat the interior with the heater prior to engaging the heat strips. Same thing happens in aircraft if window heat is applied to extremely cold glass. Should keep it from happening until a fix comes along. Of course this won't help if its happening in normal temps.
