Want vs Need Factory Bead Lock Rings?
Erjdrvr
Indy
Had a couple questions on installing the factory bead lock rings (True Bead Lock Conversion)? I have read the following threads:
https://www.fordraptorforum.com/threads/beads-locked-psis.64327/#post-1301111
https://www.fordraptorforum.com/threads/ford-bead-lock-capable-wheels.52389/#post-1097194
1) I've got a 2018 w/ factory bead lock capables & just purchased some VenomRex 17" 602's from Nick @ Apollo (He matched a competitor's price...Thanks Nick). Anyway those will be my "daily driver" wheels and I plan to purchase some KM3's to install on the factory rims. My off roading will be in Indiana, Michigan, & maybe NC or GA. Terrain would be dry dirt or Northern Michigan sand and I understand that Silver Lake Sand Dune requires running tires at 15psi. QUESTION....based on my use would there be any risk of popping the KM3's off the bead (w/o the bead lock rings) or any other benefit to the bead lock rings in my situation?
2) I also understand the Non DOT aspect and the additional maintenance required, periodic re-torqueing of the ring bolts & monitoring the PSI. But can anyone report any other experiences, positives, or negatives from running the factory bead locks (True Bead Lock Conversion) on the highway?
Thanks!
Huck
Chicago Sw Burbs
I ran my ‘12 at silver lake ever summer for multiple years air down to 15 psi and never popped a bead in the sand or jumped up to 25-30 for ORV trains. Most of the time in groups of raptors and never had anyone pop a bead on non-bead lock.
You have to drive pretty hard to pop a bead.
It may not be worth it for your application
