mkarlin27
On the ford tracking website my window sticker has populated and it says "In Production". Window sticker won't open yet, but is on the page so feel like that is positive progress.
Hankfd. It took 9 weeks before I had any info. And I too hope worth the wait6wks in and I got nothing but a receipt so far for. 1k deposit. It is a long wait but I think it’s worth it to get exactly what you want
under where it says special order are the numbers 12 03 19. thats the date the parts get sent to the factory, the truck usually gets built about a week after that date. fyi the dates will jump around a lot, my truck actually showed up almost a week early.
I don’t know if it changes but if you get the more detailed print out from your dealer like I did that number on the window sticker was the same date listed from the dealer labeled as parts sent to factory.I thought you go off the Blend Date. That's the date the truck will be "blended/added into" the production line. The date under Special Order is the date the order was processed by the factory which is typically several days or a week before the blend date aka the actual production date. In this case his blend is 220191210 which would be 12/10/2019. The 2330 is the assigned semi-sequential place in the production line.
