Vossen HFX-1 in 17x9 ET+0 offset with stock 35s
EricM
OHIO
Stock wheels are 8.5 and +34.
Looking at a 9" wheel vs. a 8.5" wheel, it's 1/4" wider each side.
Then you look at the offset. Stock is +34, those are +0. 34 mm = 1.33".
Assuming the same tire- the outer edge of the tire should be 1.6" further out, and it looks like it. You are going to sling some crap up on the side of that thing!
B
beemerb0y
Los Angeles
Yup.
Good info.
No sling so far the past few days!
Hemmy
Indiana
Yep. Trying to find the perfect wheel with + offset that also looks good is damn near impossible. Unfortunately, most wheels have a 0 offset.
EricM
OHIO
Yes, a good looking, properly sized, hubcentric positive offset wheel is nearly impossible to find.
People are FAR more interested in looks than performance. Ask anyone putting +0 offset wheels on their truck to explain scrub radius and how changing the wheel offset affects it- they'd look at you like you had two heads.
EricM
OHIO
That's a good summary.
Ford set it up right, going wider does you no favors other than looks.
