Used FORSCAN now Wrench light. HELP
julien194b
Europe FR.
yeap, you have certainly done somethong wrong, forscan is easy to use, but you have to stay focus in order to avoid stupide mistake. Also , the first thing to do when you connect for the fisrt time is to record your truck 's factory configuration, save in a specific file all the "as built format". Plenty of good video on you tube to help you how doing.. No doubt you will manage to come back !
FP_RPTR
FP_RPTR
California
Yeah .. I think it might the the cable .. is it normal for it to start going hay-wire as soon as u plug in the obdii?
Are you pulling the cable before ignition cycling, to commit the change?
after committing the code change via Forscan, you need to cycle the ignition 1x. After that, you should shut down, then remove the cable.
FP_RPTR
FP_RPTR
California
I do Ignition cycle . But I don't remove cable every time .
But as soon as the cable is plugged into the ObII it's starts to notify me of check
Powertrain Malfunction/Reduced Power
Pre-Collision Assist Not Available
Hill Descent Control Fault Warning
Restraints Indicator Lamp Warning
Hill Start Assist Warning
.etc all the errors including the Wrench Icon . And immediately on Forscan the DtC are back after clearing them
FordTechOne
Detroit
Are you plugging it in with the ignition off? If it only sets the faults when the adapter is plugged in that’s a indication that the adapter is bad and is affecting network communication.
FP_RPTR
FP_RPTR
California
Well as soon as inconnect the adapter and turn the ignition on , without plugging into my PC . The errors begin to notify .
Once I open Forscan all the DTC populate
and the wrench icon stays on after I reset everything .
FordTechOne
Detroit
Sounds like an adapter issue for sure.
yeah, starting to sound like your obd2 adapter. Good luck!
