Upgraded speakers
dhmcfadin
So what is the difference between the Axxess AX-DSP-FD2 harness and the For-11 CK harness?
The axxess harness is designed to plug into an axxess dsp. It has axxess’ proprietary plugs on it.
The for-11ck harness is used when adding aftermarket equipment. It will provide signal to your dsp and amplifiers without having to modify, cut, or splice the factory harness.
fastroads
fastroads
Austin, TX
Ok, good to know. I had seen a video on YouTube from an installer that used this particular harness to connect similar equipment.
