Upgraded IWE gear replacement interest
Are you interested in an upgraded IWE gear?
  • Yes definitly
    Votes: 82 71.3%
  • Not at all
    Votes: 2 1.7%
  • Maybe Later
    Votes: 31 27.0%
  • Total voters
    115
BIGt0007
CT
Rcv already makes Iwe gears.... Best way is to get rid of it period and run your axles full time....
I would buy that! Eliminate the IWE all together! then when you activate 4x4 only the transfer case engages. Does it bind the front end to just drive with axles engaged all the time?
hagak
No it would not bind the front end. You would have more drag so less mpg, and more wear and tear on the front drive train parts. Now not sure if the Torsten diff would cause steering to be a little heavy.
MatMan
AridZona
Blew mine yesterday at Snoball dynamically rescuing another truck....the day I hit 50,000 miles :/ We changed it on the trail in less than an hour. That being said, I would rather not lose the front wheels and would pay for insurance.
When you say dynamically, do you mean you were using a kinetic recovery rope or were you using a static strap?
This is pretty unnerving, if using a kinetic rope.
DocSpooK
TechsAzz
Dynamic recovery with strap :/
I know, I know. Kinda dumb
CoronaRaptor
CANADA
I'm interested. When are they available? Buying other parts and getting ready to install stuff within the next 2 months :)
HAYNES OFFROAD
HAYNES OFFROAD
aka Wreckless
Bourbonnais, IL
Still in test phase and in preproduction. I would love to release before TRR but only time will tell.
I plan to release 2 versions.
Version 1 will be a direct replacement, OEM functionality.
Version 2 will be a IWE delete. Hubs will be locked full time, disconnect at transfer case.
I am also developing a complete IWE vacuum system replacement kit. OEM functionality. looking at summer/fall release for this. Stay tuned. :)
As for RCV having these IWE deletes, yes it seems they have made some. But I do not believe they are available to the public as of yet.
JJ f150harley
Traverse City MI
I'm just a lowly f150 owner, but I would for sure be interested, mine pop every time. How much wear are we talking with the iwe delete? Cvs prematurely needing replaced?
