Typo in Forscan spreadsheet ?
Antho
yes and no. You see the mod is called " Engine temp & Transmission temp" ..2017 and up has no Transmission gauge on dash. All you have is oil pressure gauge, coolant (engine) gauge, turbo gauge and gas gauge. last 2 come with numbers , measurements preset. Mod enabled temp numbers on coolant gauge.
You either have boost or trans temp. You change it in the cluster. 2017+ absolutely has trans temp gauge…Who told you 2017+ doesn’t have trans temp gauge? Same person that told you there is no washer fluid “module”?
Dancam
Arizona
Step by step how to replace the turbo gauge with trans temp gauge on the dash. I'm sure that will be easy for you. Also my truck came without any washer fluid and never have had any warning the fluid was low (have to look into why I got no warning). Every single dash screen shot I see of any trim 2017+ has no trans gauge temp . You do have a trans and oil temp but you have to search for it in the menu. Not my dash SS but mine looks identical. Replace top right "turbo" with "trans gauge" how to please
zemuron99
Seattle
You can have all 5 showing, that's what I keep as my default display in my '17 802a. You just have to go into gauge view to select a change from trans temp to turbo/vice versa, and not make a selection (i.e. don't push the OK button in this view). I prefer the turbo boost pressure display in the center. Yes, the turbo gauge functions in this display even w/out being 'selected'.
blwn
Florida
Don't worry about the 'E' already being there. Most of the modules have been mapped out already showing which each function means, just know that if it specifies E5 there, you need both values set to that for it to work. It doesn't necessarily mean one won't be the same as what is already there.
The '19+ do not allow you to set the top right gauge to the trans temp. They do have the Gauges function though that allow you to select Trans Temp as one of the options. They also have the Measurements screens which show all the live raw data.
As far as the Windshield wiper warning, that is because when you made the change in the IPC, Forscan reboots that module. Making most Forscan changes will bring up warnings the first time it boots up.
You can set Nav in Motion, which is just changing the country code to one that allows those functions. Be aware your speed limit signs will change to the Euro style look and the 911 assist will be disabled. Also it has been mentioned on other forums that newer versions of SYNC 3.4 allow changes in motion if a passenger is detected. It will prompt if you're a passenger. I have not tried this myself though.
Dancam
Arizona
Thank you for explaining why I cant add the trans temp to the right gauge. my mistake was saying 17+ raptors ( hence the reason 2 17 owners posted how to) but is actually 19+ that cant do it. So, the forscan mode only adds coolant temp to 19+ and nothing else. Did I get it right?
