Today i messed around with Forscan.. . I got stumped by "Engine temp & Transmission temp shows above gauges (8" Clusters only)". The spreadsheet has "IPC 720-07-01 xxxx xE5x xxxx ** use this if you have trailer brake controller and turbos **. Raptor 2020 has already E in place and I had to add only 5. Is it a mistake in the list or I'm doing it wrong?Posting the unmodified module pic
So as Raptor owners we need to change JUST xxxx xx5x xxxx CORRECT?
PLEASE take a look at lines 67 to 70 in the spreadsheet
https://docs.google.com/spreadsheet...MMbEzZQbEaG24JZtbMfsok6vrYLqRyY#gid=815852466
