TurboSmart EM BOV
Dustan
Boulder Colorado
I just picked up my TurboSmart BOV EM in Sydney. Looking forward to getting it on the truck. I have a similar setup with the Cobb FMIC. Any tips on getting the valve in there? Did you just cut the breather hose and leave it or did you tie it up somewhere?
I ended up cutting the hose as short as possible, which is fitting to fitting and Then using the plug. It’s really flimsy with the Cobb breather hose at original length. It will work fine but I’d still like to find a plug that that fits the intake pipe. The new BOV fits really great on the pipe Cobb made.
Mbdurham
Georgia
I installed mine tonight. I am running a Cobb FMIC and ADD bumper so it was super easy. Maybe 30 minutes or so. Haven’t driven it yet but will test it out tomorrow. I am going to either cut the hose or find a cap or something. I zip tied the hose to the frame for now.
Edit:
Maybe something like this. Need to make sure of the hose size
Prescott Plastics 8 Pack: 1 1/4 Inch Round Black Vinyl End Cap, Flexible Pipe Post Rubber Cover https://www.amazon.com/dp/B0747RVMRZ/?tag=fordraptorforum-20
Second edit:
Just measured the fitting on the stock BOV and it’s about 1 1/8 so I ordered the 1” and 1 1/4”
Mbdurham
Georgia
If anyone is worried about it being too loud it definitely is not. I had to roll my window down to hear it.
Dubai
All good installed today on Cobb pipe (I have Cobb FMIC). Really simple install with one bolt to undo on the existing BOV. Twist and replace..
And then put the blank in the end of the Cobb pipe:
To finish I cable tied everything to make it neat. I'm going to be putting a winch in that space in the near future so will tidy up properly then:
Sound is good, not very loud and appears to be inconsistent when it blows at the moment.. I'm sure I'll get used to it.
Only problem I had on the install was removing the skid plate.. The front end has taken a few knocks in the desert so the bolts are really tough to turn. I ended up snapping 3 out of 4 of the little metal brackets. Anyone know a part number to order some more brackets and bolts?
Pure745
Orange County
Hopefully a fluke thing. Was gonna install mine today. First issue Ive heard.
Normal driving? Or pushing it to test it?
Was also going to install mine today - hopefully this isn't common. Also saw he had the COBB FMIC, maybe that had something to do with it?
Jburns1122
Los Angeles, CA
Error code this morning - P0035 Turbocharger Valve A control circuit high.. anyone else?View attachment 138168
Odd for sure...any chance you may have damaged the solenoid on top when you installed it? I dont have them in front of me, but I recall the instructions being very particular about taking "special" care not to damage it or twist the wiring or something.
