TSB 11-4-7 - Third Brake / Cargo Light / High Mounted Stop Lamp TSB/SSM and Fix
shthpnz
Madurodam, Holland
Can the unit be disassembled so I can get rid of the greenish / black residu on the bottom side of the transparant lens?
shthpnz
Madurodam, Holland
I found the answer on my own question. I could not open the unit, but was able to rinse the greenish - black residue away with a brush under the tap. Dried it and added a bead of caulk on the rubber and also in the outer edge of the lens. Now the moisture can't make the lens greenish again.
pirate air
will plunder your booty
TSB 11-4-7
04/27/11
TRAC CONTROL FLASHING / ILLUMINATED WITH
DTCS C1278, C1280, C1282 AND C1963
FORD:
2009-2011 F-150
This article supersedes TSB 11-2-5 to update the vehicle model years.
ISSUE
Some 2009-2011 F-150 vehicles built on or before 3/21/2011 or 2010-2011 F-150 Raptor vehicles built on or before 3/28/2011 may exhibit a condition where the Trac Control indicator is flashing or illuminated with diagnostic trouble codes (DTCs) C1278, C1280, C1282 and C1963 stored in the Anti-Lock Brake System (ABS) module. In addition, some customers may complain of intermittent nuisance activation of the Electronic Stability Control (ESC) during low speed turning maneuvers while towing a trailer only.
ACTION
Reprogram the ABS module to the latest calibration using IDS release 72.01 and higher. This new calibration is not included in the VCM 2011.3 DVD. Calibration files may also be obtained at the website.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
110407A 2009-2011 F-150: Check 0.3 Hr.
DTCs And Reprogram The
ABS Module (Do Not Use
With Any Other Labor
Operations)
DEALER CODING
CONDITION
BASIC PART NO. CODE
2C219 04
crashmc302
Idaho
pirate air said:
TSB 11-4-7
04/27/11
FORD:
2009-2011 F-150
ISSUE
ACTION
Operations)
DEALER CODING
CONDITION
BASIC PART NO. CODE
2C219 04
Ur my hero
khcdave
South Brunswick NJ
Anyone have this issue with 2012's? Mine is at dealer for the second time for these faults. Told them to check the third brake light.
BIGt0007
CT
Great write-up, BigJ. I'll probably do this when I pull the light off to smoke it out.
I hear Birdman prefers black caulk though...
here we go with the caulk jokes!:ROFLJest:
BigJ posted the pic of his small white caulk ............ sick bastard!
Hockster
My 45ft Bluewater Party
Winchester, Va
Damn this just happened to me today.
Ha ha ha mine did it today... Leaving for northern Mi tomorrow too... Go figure.. As least I have the equipment to clear and fix here... If only I still worked there I could get the updates and reflash myself... Oh well, I think its time to trade in and get me a 2013!!! Going to dealer for a written trade in estimate...
