Truck won't turn over
d.p
d.p
Swapped the 20 with another 20 in the fuse box to no avail. Will try a new one but if not it will get towed to the dealer.
d.p
d.p
Swapped 27 with new one and no change. Maybe bad gas? Got gas last night.
CoronaRaptor
CANADA
Canister purge valve? How many times have you tried to start it? When mine went, it wouldn't start until the 3 or 4th time from continuous cranking over
Have you tried disconnecting the battery and reconnecting it. How about using your other key?
d.p
d.p
Tried a bunch of times no luck. Didn't have the tools to disconnect the battery but do know so I will try that and my other key. Whats odd is that it started just fine then died and wouldn't start. It acts like it's going to start for about 5 seconds then turns off.
d.p
d.p
40" light bar that's it.
---------- Post added at 06:43 PM ---------- Previous post was at 06:18 PM ----------
Yeah neither made any difference. Getting towed to the dealer shortly.
---------- Post added at 06:51 PM ---------- Previous post was at 06:43 PM ----------
Waiting for the tow and now it's saying "hill descent fault. Service advance trac. Check brake system."
