BSouders80
I found the issue. Checked the fuses in the fuse box under the hood and had a bad 15 amp fuse. replaced the fuse and all is good in starting.
Now you just need to figure out why the fuse blew. You either have a high amp draw or an intermittent short to ground.I found the issue. Checked the fuses in the fuse box under the hood and had a bad 15 amp fuse. replaced the fuse and all is good in starting.
