Triple Fog Light Kits Featuring 100% American Made/Stainless Steel Brackets
Braaaaptor
Starbucks Enthusiast
The drive-thru
Thanks! Do you or does anyone else know if using the Baja LP9 / 6 will block the adaptive cruise control radar in the 2019 Raptor?
They shouldn't if they're mounted above the bumper. The ACC sensor is behind the square bumper trim between the IC cutout and fog light cutout on the driver's side. You'll limit your front camera with those lights depending on how many and where you mount them however.
4x4TruckLEDs.com
4x4TruckLEDs.com
Now that I've researched some of the cost, maybe I should go with the LP4s... :signs8:
No it does not block the ACC module. That module is located in that block plastic cover on the bottom of the driver's side. Nowhere near the lights.
4x4TruckLEDs.com
4x4TruckLEDs.com
Patrick had the following to say. Simple and to the point
The brackets made the light installation and adjustments very easy; highly recommended.
and Kevin had the following to say
he Baja Designs Triple fog light kit is a great addition to my 2017 Raptor. I ordered the SAE wide cornering, wide cornering amber, and Pro driving/combo. The Pro is super bright...read more
Grab your kit from us today
Baja Designs Sportsmen Kit: $729 (MSRP is $780.97)
https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights-sportsmen/
  • S2 Sport, Wide Cornering (Pair)
  • Squadron Sport, Driving/Combo (Pair)
  • Squadron Sport, Spot (Pair)
Baja Designs Pro Kit: $989 (MSRP is $1,068.97)
https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights-pro/
  • Squadron Pro, Driving/Combo (Pair)
  • Squadron Pro, Spot (Pair)
Baja Designs Unlimited Kit: $1,204 (MSRP is $1,321.87)
https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights-unlimited/
  • S2 Pro, Wide Cornering (Pair)
  • Squadron Racers, Spot (Pair)
And of course you can Build Your Own Kit: $729 (starting price)
https://www.4x4truckleds.com/2017-f...ght-kit-w-baja-designs-lights-build-your-kit/
Don't forget Ford Raptor Forum members get an ADDITIONAL 5% OFF the prices above when you use coupon code FOGS at checkout!
We've also got kits available with Rigid Industries lights
Rigid Industries D-Series Kit: $689 (starting price)
https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-d-series/
Rigid Industries Radiance Kit: $549 (starting price)
https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-radiance/
Rigid Industries 360-Series Kit: $1,059
https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-360-series/
4x4TruckLEDs.com
4x4TruckLEDs.com
Fresh back from production we've got full stock on our CrystaLux Triple Fog Light Brackets + Baja Designs lights!
Check out this video that goes over the many features of our brackets. Designed to be the only mounting system you'd ever want for your truck, our brackets offer you more adjustability options then any other bracket on the market. PLUS, our Raptor Lifetime Guarantee.
4x4TruckLEDs.com
4x4TruckLEDs.com
Tom just picked up the Radiance kit and had the following to say
Love the look and love the light output. Easy to install and infinitely adjustable. I ended up putting weather pack connectors on the light ends to make install cleaner and to make sure I can working on things easier down the road. I combined the main leads at the up fitter end so that I could plug a single wire into the truck side and have 1 switch for all 6 lights. The back light got run to the side marker light for power so that when my stock running lights/ marker lights are on these are backlit. Couldn't ask for much more here.
Grab your Triple Fog Light Kit here: https://www.4x4truckleds.com/vehicl...2017-2018-f-150-raptor/triple-fog-light-kits/
4x4TruckLEDs.com
4x4TruckLEDs.com
Jonathan and Matt had the following to say about our Triple Fog Light Kits
Overall easy install, I bought the extension brackets and they were great for keeping the lights right side up. The install was easy and the wire harness was fantastic, really made the wiring super simple. Had some challenges lining the lights up to be identical on each side, but after taking some time to adjust them they are good. Lights look great on and provide an amazing upgrade.
Will be coming back for more! Fast shipping and great support.
These gentleman both went for our Baja Designs Pro Kit. That includes a pair of S2 Sport in Wide Cornering, a pair of Squadron Pro Spots and a pair of Squadron Pro Driving/Combo
Right now Baja Designs has 4-6 week lead times, however, that's not the case with us. We've got PLENTY of lights on the shelves. Everything from S1 kits down to the LP Series.
Order by 1pm EST and it'll ship the same day from us.
Pick/Choose the lights you want or go with one of our pre-configured kits. All ready to go and available right here: https://www.4x4truckleds.com/vehicl...2017-2018-f-150-raptor/triple-fog-light-kits/
4x4TruckLEDs.com
4x4TruckLEDs.com
We treat every customer like family. Mike had the most kindest words to say about his new Baja Designs Triple Fog Light Kit
I would give 6 stars if possible. Best experience one could ask for. I was somewhat dragging my feet on installation because I have only installed one other item on my upfitters and was not looking forward to figuring out all the wiring of six pods on three switches. To my great surprise, the wiring harness that 4x4TruckLEDs has put together made this INCREDIBLY easy! Seriously... It is the best harness and mounting hardware on the market by far. I looked at several vendors and searched many install videos on YouTube. This was WAY easier than any of the videos shown. One harness that plugs into each light and goes straight to the upfitters and ground. Simple. Adam from 4x4TruckLEDs was incredible to work with. He is an expert in the field, so trust his advice on selecting the correct product for your application. I would have purchased a good product, but not great for my needs. He steered me in the right direction. Next up, BD reverse lights. I will only be purchasing from this company and will be consulting Adam to figure the best light pattern for my needs. And, I will definitely be getting the upfitter wiring harness for this one as well. Best money you can spend.
Happy to have you as a customer Mike! And please enjoy your new killer setup.
