- Joined
- Jul 18, 2017
- Posts
- 2,978
- Reaction score
- 1,393
On the Rigid Radiance kits you'll use 4 upfitters. 1 for each pair of lights, the 4th is for the back lighting. Our harness has a control wire for each light you connect. Pretty easy.
If you don't want to use your upfitter we can (at no charge) include a fuse tap which you would use to connect to an available circuit in your fuse panel. We don't make you run a wire into your cab or take apart anything inside there. The fuse tap is the easiest way to do it and there are plenty of circuits in there that come on when the truck is on. So this is an ideal method.
Baja Design kits don't have a control wire, as they don't have back lighting. You get more patterns with Baja and more light output.
