Drgonzo3000
I have a weird shifting issue that only seems to be present on the first drive of the day. The issue is always that when I first get going the 5th gear shift is messed up. It seems to hang trying to shift into 5th gear and after a second or so catches itself and everything is fine. Normal acceleration it does it where it causes the truck to jerk, doing it on a hard acceleration is when it's the worst and about puts you into the dash. Either way it feels like the truck goes into neutral before it makes it into 5th and it seems to slowly be worse. Again it only does this on that first drive/shift, after that it never happens again, even if I park the truck and don't drive it for hours. Next day it does it again.
Truck has the most recent trans firmware which fixed the stock hard shifting in every other gear. I have a Gearhead engine and trans tune, but even going back to stock the problem persists so it's not a tune issue. Truck is at 55k so I still have powertrain warranty and will be making an appt here soon. Figured I would see if anyone had any insight. Didn't find anything that sounded like this issue on the forums.
