F1502raptor
14’ with 80k miles, no open recalls
When starting up cold, say between 30-60 degrees, I will let the truck idle until it atleast idles down the rpms before shifting to reverse. Seems to shift fine into reverse, then when I go to select drive it sometimes has a firmer engagement that can be felt in the truck. No grinding and trans works as normal all other times
Seems to only be when cold and selecting drive for the first time (after first time selecting drive, you can go back to reverse and then back to drive and doesn’t do it again. No gear shifting issues whatsoever. Just the firm engagement when selecting drive when cold.
Maybe too much line pressure when it first gets put into drive?
