You're only supposed to brush a film on the inside of the yoke.
Anything more will mix with the transfer case fluid. Not good!
As the chain rotates around in the transfer case it's suppose to lube the output shaft, suppose to!
Unfortunately it doesn't work very well so when the yoke gets old and the nickel plating wears off,
then it's time for a new yoke or start greasing.
