Toyota guy considering going 13 or 14 raptor
Sozzy12
Montana
I'd be more concerned with rust than miles. The drivetrain should be able to go 250K easy. Might need to have the blower re-built at some point, but that's only about $500 through Whipple. Bearings and seals typically.
I'd also recommend the 13-14 models for the Sync 2, HIDs, front cam, and front torsion diff if you are mostly on the street with it. However, if you do a lot of off-roading, some guys like the older models without the front torsion diff as they think the torsion diff causes more breakage than non-torsion trucks. You can always swap it out if it's a big deal one way or the other.
Front camera and torsion front end started in 2012.
My money is on the lower miles. You can always install a super charger later.
