Purchased my 2010 Scab with 90k miles, Dealer maintained and no record of any tranny service. I'd like to skip the power flush. I picked up a factory tranny filter and gasket, plan to drop the pan and change the fluid myself.
Has anyone tried to do their own flush by removing the trans cooler return line? I saw a video on Youtube in which, by adding fluid continuously, all the fluid is replace, even through the torque converter.
Otherwise, how long will I need to drive it to repeat the process until it's all changed? Will I need to drop the pan and replace the gasket each time?
Is it better to change the filter on the first fluid change or the last?
Finally, any preference between Amsoil and Motorcraft LV fluids?
