jeeper
ive been havign the same problem...what is the fix for this?
Hrm, my 2012 doesn't do this except for when I DID break the front axle. I'd be concerned.
Punching it up a sand dune the front axle said PING!!!! CLACK CLACK CLACK CLACK CLACK!!! And then I had no front wheel drive.So, do tell what the problem was please.....? and do you still have the bang bang noise with your new axle assembly ?![]()
The way to fix this is to get rid of spring and diaphragm all together.. Replace the moving gear ring (which is less than 1/4" ) with a solid machined 2" gear ring to solidly lock the cv axles to the hub. And just use the transfer case to shift in and out of 4wd. I am waiting to get some trashed IWE and see what I can come up with..
-Greg
