MTF
I would say you may have partially frozen/stuck calipers.
Precise machining attempts to overcome a issue but proper torque is still needed. Metal is malleable and beyond a certain point it will not return to prior shape when pressure or force is removed. The distortion spreads through it with time, heating and cooling accelerating the deformation. And as I pointed earlier that will spread to adjoining surfaces such as the hub which likely requires another precise surface for bearings. The wheel also. The requirements of space travel to overcome possible issues is too expensive for a earth bound wheel. Especially when using a torque wrench overcomes those issues.Over torqueing lug nuts doesn't ruin the rotors whatsoever. Maybe 30 years ago, but lugs haven't been anchored into the rotor for decades. All you are doing now is squeezing the hat tighter between the wheel and hub face, which does exactly nothing to the rotor.
So you think they have better capabilities then the entire testing lab of the American Society of Mechanical Engineers? A few years ago their results were public. To get a copy of that you would now have to pay for the publication containing it which is why I have not posted those results.We need to get project farm to do some testing on the accuracy of torque sticks
TWO points. #3, they can be equally bad at overtightening which happens when using an impact gun with a relatively large degree per stroke. That stick will not make a click or other signal that you have reached the proper torque. Think of it as the torque wrench and as you go through a stroke you ignore the click and keep going. And once you put that dent from to much pressure how do you remove it? Depending upon the resiliency of the metal one over torque will be damage undone without replacing. How much damage and cost are worth it?My thoughts regarding torque sticks:
1. Not all are the same, they are a number of manufactures who make them.
2. Most of the kits I've seen don't have a 150 ft.lb stick. Our lug nut requirement is 150 not 140.
3. They can't prevent under tightening unfortunately. I have had good success with them preventing over tightening.
4. A torque wrench can be just as inaccurate. Especially when it bounces around in our trucks. When was the last time you had your torque wrench calibrated?
5. A torque stick will only be a good as the the air system powering it. Many impact wrenches require a significant amount of airflow to achieve their rated torque value. That rated torque value is reduced significantly when that airflow isn't achieved. Just because your impact wrench is rated to 250 ft.lb + doesn't mean it will do the job.
6. Max torque and nominal ( sustainable) torque can be very different. You need much more available torque than the stick you are using.
So how do you determine if you equipment works? By testing.
Unfortunately, most torque wrench companies do not provide you a range of torque data to allow you to correlate the right information to your airflow and pressure. You also need expensive equipment to check pressure drop in your airlines.
My suggestion would be to calibrate and test whatever system you are using.
Sent from my STV100-2 using Tapatalk
#4, a torque wrench is a calibrated instrument and should be treated as such. Many come in a protective case that IS TO BE USED!
