Torque Pro Dyno
MTF
Celebration, Florida
You can look up Ford PID codes on the internet, I never had the chance to play around with them.
The PID codes are probably going to be different from 2010-2014 to 2017-2018.
I can only give you my little experience on a 2010 1/2 6.2L Raptor.
I did not see any change in HP playing with weight in the Torque Pro App.
Isn't the RWHP on the 3.5L Raptor like 345 and 450 at the crank. ( No Tune )
Gear ratio and tire circumstance would have to be calculated with the weight for accurate reading, that would be my guess anyway.
10SpdsOfFury
Jacksonville FL
Any good iOS/iphone options? Looks like this app is android only.
I found OBD Fusion (not obd torque) in the IOS app store and went on amazon and ordered a OBD2 Bluetooth adapter.
Thing works pretty sweet but I got it last night so still messing with it. I did create a custom dashboard so going to play with that today.
CSJr
CSJr
GA
What is the PID for octane?
---------- Post added at 05:13 AM ---------- Previous post was at 05:09 AM ----------
So, when I jumped on it, my HP gauge would say a maximum of like 140hp. I checked and my weight was set to 1600 kilos. I changed it to 3266 kilos, and now my horsepower is reading much higher, like 400s, whenever I jump on it.
Got this from another board..
Learned Octane ratio* (See this thread for Explanation)
Learned Octane Ratio (LOR) Gauge in Torque
Another note on LOR - It appears to only look at knock seen under 4k RPM and 1.5 load (Credit to AJPTurbo) in other words at part throttle conditions.* It won't look at WOT knock and adjust the LOR directly however if your LOR does change it is believed to affect your WOT timing.
PID 2203E8
Formula - (Signed(A)*256+B)/16384
Re. weight. I personally think it needs weight for that calculation. MTF says otherwise, but I haven't tried anything weird yet. Speaking of weird, 3266 seems a little high.. (7200 lbs)
gijosh28
I felt like that was high too. I asked google how much a crew cab raptor weighed and it said 7050. I rounded it up to 7200. I am sure you're right though. I am sure that is more than a little high. I will probably go to the scales at my work and check to see what it weighs. But it definitely affected the results I was getting in Torque Pro for HP numbers.
https://www.google.com/search?sourc...y-ab..1.9.1290.0..0i67k1j0i10k1.0.Ed-S3h__wZU
Josh
10SpdsOfFury
Jacksonville FL
Josh
I weighed mine on a cat scale full tank 2017 Super Crew 802A Full moonroof and cast wheels and it was 6280lbs with me in it 6’4 290.
gijosh28
A 6000 pound F-150. Isn't that nuts?
What did they charge you? I think the cat scales here is like $12.
---------- Post added at 02:09 AM ---------- Previous post was at 02:02 AM ----------
Made a new video showing two sets of torque gauges, and youtube working on Android Auto. Sync v2.3.
https://youtu.be/eOIp0q2qz3U
