GEN 2 Tonneau Cover
jgree32
Where are people putting drain tubes for the retrax?
Thinking about getting one and glancing in the bed I don't see any holes for it.
Do you have to drill?
nah_tan
+1 to this. I have a spray in liner and couldn't tell from underneath where the drain holes are.....my plan is to just route them under the bed rug bed mat once it arrives.
Mach'er
Anybody have the UnderCover Ridgelander? I'm looking at getting one for my SCrew, but see very few reviews (and one of the few is negative, mentioning fit issues).
I like the idea of the rack above the tonneau. Tow the toys (boat or PWC), bikes on the rack, gear in the bed. Long weekend at Silver Lake. Ideal, unless it doesn't fit on the bed well, as the guy claimed.
So, does anyone have one, and if so - how do you like it? Or, suggestions on other available tonneau covers that gives similar functionality?
Thanks.
crash457
I'm Batman
St. Louis, MO
I drilled holes in the bed plugs on the front of the bed for mine. I was going to have them pull the plugs out when they did the Line-x, but they said that they wouldn't fit back in afterward. So they sprayed over them. I was able to drill a pilot hole easily even with the Line-x and then open it up with a step bit. If you use a standard drill bit, be sure to tape it so you don't go to deep and hit the cab when you drill through. If I ever want to remove the cover, I can cut the Line-x around the plug, pull it out and replace them (they're like $12).
FullSend
Colorado
Thanks.
I plan on going with 'Truck Covers USA' American Roll Cover. It is retractable and has the integrated rack above the cover. It also claims 500lb capacity on top of the cover (dispersed). I like the idea of being able to retract the cover to access gear while having toys still loaded on the rack.
CFIT
Valencia, CA
What's the price of that unit with the racks and everything?
FullSend
Colorado
It comes out to $2,154 for cover, rack system, rack mounts to bed rails, and keyless entry handle. That was on autoanything and with free shipping. Haven't looked around much passed that. Looked at the pace edwards ultra groove also but it's not rated for weight on top of the cover.
CFIT
Valencia, CA
That seems like reasonable value, provided the quality is good.
Lunk
Morrie at Tonneaufactoryoutlet.com matched the lowest offer I had on the bakflip F1 and was awesome to deal with!
IHAVETWO
NY
17 hard cover tri covr.pain to remove completely.no tools needed soft cover much easier.
