TMX Test Drive – Shock Comparison between Fox and Icon
ntm
Alberta, Canada
The icons are up around 650-700 I believe.
Corey adjusted his front bypasses as well.
when you mention the front adjustments do you mean just the secondary shock not the coil over on the front. I thought that the coil over would have to be removed and opened up. thanks in advance
That's correct. External bypass adjustment only, as it does the majority of the work.
Coilovers are set low at the shop to allow a wide range of adjustment via the external bypass shock.
wanderfalk
are the adjustment compression and rebound dials on the icons and fox doing the same thing, or are they different due to inherently different designs?
Mjolnir
Colleyville, Texas
Rebound and compression use the same principle between vendors, however the varying rates of compression and the degrees to which you can adjust differ
Mjolnir
Colleyville, Texas
Fronts:
20 compression / 20 rebound
i'm at 7 threads on preload, but going to 3 on drivers / 4 on passenger when I get it aligned next week.
rears:
2 1/4 turns on blue long and short
3 on red
Here you go. Settings I currently have
wanderfalk
so if you turn the dial fully counter clockwise or to zero, you then go nine clicks on the compression tubes and twelve clicks on the rebound.
