Morning fellas, so I took the car into Ford for its service to be looked at.
They've assured me the rear end is for a raptor and there is no issues with the suspension, in terms of rear shackles or bushes being worn. They did a wheel alignment and there was nothing wrong there either.
The only suggestion they could give so i was deflating too low and that causing the rubbing. When in the sand I go down to 10psi for the rears and 12psi for the fronts. Bear in mind though, this rubbing is only happening on the left hand side.
I told them I was not happy with the diagnostics and they've suggested they paint the worn shocks today and then we take a look at them next weekend after I've been in the desert again, then we can tell if its still happening or if this is an old issue that's already been resolved.
I'll get them to raise the truck this evening when I collect so I can take pics of the leaf springs to show you guys.
There was also wearing on the handbrake cable, but they told me not to worry about this.
Not really sure what to think. Normally a dealership garage will tell you there's loads wrong as they want your money.
