Tire size decision-help
BIRDMAN
Birdministrator
Boston
I'm stuck on what size tire size to go with...
325/60/20 or 275/65/20.
The 325s are about an inch taller and and a little wider than stock $415 each - 67lbs
The 275s are about the same height as stock and an inch skinnier. $290 each - 57lbs
See my dilemma? I'm gonna spend 450 more on the 325s, and they are alot heavier. The 275s seem good but are they too small?
Sent from my right thumb using Tapatalk.
comagt
New Braunfels TX
I would imagine the 275s having a horrible driving experience on a truck like the Raptor. That's a lot of rubber real estate to give up on all four corners.
BIRDMAN
BIRDMAN
Birdministrator
Boston
but...better rain and snow traction with a skinnier tire ?
Humvee21
It really depends on snow. There's different types of snow and how deep.
If the snow is soft and not too deep, I'd go with a skinnier tire so the tire can cut through the snow and touch the ground. If the snow is very deep and thick, wider tires to give you most surface area to float on top of the snow and maintain maximum traction
NY SCREW
new york
are you getting these as all around tires or snow/winter tires? if these are all around tires ild say get the cheaper ones, an save up an get some snow tires best of both worlds ....if thats affordable an a option other wise get the bigger ones imo
whisler151
Dallas, TX
Hockster
My 45ft Bluewater Party
Winchester, Va
IT depends on where you are driving the most. If it were me I would get the skinnier tires cause I drive on the road 95% of the time. They will fuel better...
Aaron
Meme Corps Commandant
WA
Bird, what kind of tire are you going with?
If it was me I'd do the 325s just because I don't think the smaller tire would look right, but not having seen them I can't say for sure. I just feel like anything smaller than stock just might not look quite right.
BIRDMAN
BIRDMAN
Birdministrator
Boston
I'm looking at Duratracs so I will run them all year
