Whats a man key? Is mine normal?
Asking for a friend
Asking for a friend
If you disabled it via ForScan then it also disables the BMS (battery management system). Not sure what effect that actually has on longevity of the battery though.
Took it back to the store twice. The second time I came back from a 200+ mile trip straight back to the store and it had 46% charge. Had Ford and my shop check alternator and electrical and they found no issues except with the battery.Sorry for the bummer experience. There’s got to be more to the story. Did you bring the battery into the store dead? Meaning very low voltage?
Had you ever run the battery way down?Took it back to the store twice. The second time I came back from a 200+ mile trip straight back to the store and it had 46% charge. Had Ford and my shop check alternator and electrical and they found no issues except with the battery.
You'll have to post a pic ... on second thought, you're just fine. Completely normal. For some value of completely. And some value of normal.Whats a man key? Is mine normal?
Are you sure that it doesn’t go out after 15 minutes or so when the power to the usb goes off? I just ran out to the garage and checked my 2020. Light is off.
Down to 26%, on it's own.Had you ever run the battery way down?
Maybe it's older models that have this. I waited awhile. Also, Accessory power should be killed once truck is turned off and locked - hence no radio or other lights operable. Should be the same for the USB and the little lamp on the console compartment. No reason whatsoever for it to stay on.
