i should update. i finished my 3.5 5-tube shocks today.. I wanted to keep live valve up front on FRS coilovers with RPG RST18 and fox 3.5s on the back
i simply zip tied the factory live valve coils up under the back and kept getting drive control malfunction errors, with live valve control solonoid open circuit faults in the VDM (forscan)
I tried sticking a bolt thru the coil, and wahhhlahhhh the issue went away. some inductance thru the electromagnetic coil must be needed by my 2019 VDM truck. you could def feel the magnet working on the bolt, but this didnt happen until the truck rolled a few feet in drive or reverse, otherwise no duty cycle to the live valves..i was watching the VDM in forscan and the rear voltage was doing square waves until i put the bolts in, and then it was a very gradual ramp to a point where it stayed.. hopefully this is all ill have to do.
i didnt drive it alot, and i also didnt think to change modes until right now, so ill have to update again..
I used some stock LCA bolts i had laying around, since i did the cammed bolts on my lowers, but i'll get something that isnt so long..
