The right way to install GEN 2 Shocks on a GEN 1!
yoopercharged
Tri Cities, MI
Anybody with these installed have updates/comments on how these are holding up? I'm about ready to pull the trigger but looking to see if there's any additional feedback to consider.
Doug Mikra
Doug Mikra
San Marcos, TX
Just an update - one of our customers went BIG at a raptor run recently with our 3.0 Kit!
Going this hard takes some talent with any setup so definitely do so at your own risk. With that said, what we’re hearing from this customer it has been performing flawlessly after weeks of repeated punishment!!
Doug Mikra
Doug Mikra
San Marcos, TX
BTW, this truck is running Geisers up front, Deaver +3’s in the rears and +2 drop shackles.
Doug Mikra
Doug Mikra
San Marcos, TX
From Mikra's website: "Front shock package is recommended to be paired with a set of Rear Fox Factory 3.0″ Piggyback Internal Bypass Shocks – Ford/Fox PN. HL3V-18W003-CB."
Some guys run external bypass rears as well. Either way a 3.0” bypass shock internal or external is the way to go. Externals are a bit better off road
Goliath101
These will work with gen 1 Geiser springs correct? No need to buy a set of gen 2 ones? Also any words of aftermarket tie rod interference with the shock shaft? Looking to buy a set of these and those are my only two concerns! @Doug Mikra
Doug Mikra
Doug Mikra
San Marcos, TX
Should have no issues with aftermarket tie rod clearances and also the Gen 1 geiser springs. Seems to be most are running geisers over stock springs. Thanks!!!
