The one and only radio thread
All The Way
Lockport, NY
hey guys
I purchased and installed a TYT 900D a few weeks ago. I used it with a large group of Raptors and everyone said they could not hear me if I was more than 1/4 mile away. I can revive audio clearly from handheld, and bigger radios at much further distances.
I am using a small magnet mount antenna currently from Amazon.
What should I check to troubleshoot this issue. I am suspecting the antenna, but dose that sound possible to you guys? Any help would be appreciated.
Thanks Mike
It could be one of several things or it could be a combination of a couple. it's possible you could have bad coax, or you could have a bad antenna. It could be poor antenna location or it could be inproperly tuned antenna. Magmounts do not help your cause.
A good SWR meter will help you diagnose your problem. You will not find them at radio shack. Ham radio shops sell them or maybe get a hold of a local amateur radio operator, they may have one you could borrow.
Dutch451
Madison, WI
I picked up the Yaesu FT-8900... I think it's pretty much the same thing as the 8800, but it's a quad band.
All The Way
Lockport, NY
My best friend and a couple local hams have the 8900, it's a good radio. Only down side is unless there are a lot of 6m and 10m FM repeaters in your area you won't use those two bands often.
Wideglide93
Indianapolis,IN
OK guys I have one major question. I figured out how to program (incase anyone is having trouble you can not program a channel if it is transmitting, remove antenna). I am having an issue in that I can not listen to any of the local EMS, Fire, Or Police channels any ideas? Even local weather doesn't work. I have been able to get the national weather channel to work.
