Scott1446
Thanks Scott. That's great! I did get it back to English, but lost my programmed frequencies.
0) Turn on the radio – Use the knob on the top of the radio to set the desired volume.
1) Press “VFO/MR” – The radio will toggle between Frequency Mode and Channel Mode. The radio voice will tell you which mode you’re in.
2) Enter a Frequency – Use the number keys to enter the frequency. Don’t worry about the decimal point – it appears automatically. For a frequency of 152.000 MHz, simply enter “152000.”
3) Press "MENU" key use Up/Down keys to select menu function "MEM-CH #27" (Top Line)
4) Press "Menu" key use Up/Down keys to select the channel/memory location (Bottom Line) you wish to store the frequency in, you should hear the lady in you radio as "Confirmed"
5) Press "MENU" key again to save to that location
6) Press "EXIT" key to exit menu, go to step 2 to store more frequencies.
151.820 GLRE1
151.880 GLRE2
151.940 GLRE3
152.000 TRR1
152.750 TRR2
PS: These steps should also work on other Chinese made radios (like Wouxun), the MENU item to save a channel may be different.
