GEN 2 Tapping into bed lights?
Sean M Heard
Jenks, OK
Take a look at these from https://www.f150leds.com/collection...eds/products/17-18_raptor_cargo_bed_light_led
You run the wiring out of the bed into the cab on the passenger side. They have a video. The connection ties into your harness and they work with the preconfigured on/off for your bed and interior lights. I purchased them but have not connected them just yet. Hurricane a comin'.
I purchased these and installed but when it came time to wire, I decided against it. My harness in the rear passenger door jam was wrapped from Ford and I didn’t want to tear into that to access a viable connection. So, I’m still waiting to figure out exactly how to move forward with another solution.
Ali 556
Home
No need to all that, just tap into the rear lights for power, and you can added up to 400w of lights.
Chrisfix made an ok video about it.
Edit:
For switch, tap into the stock switch with a RELAY OR a proximity/magnet to turn it on/off.
FordTechOne
Detroit
be careful. I’ve tried this and threw a DTC on the BCM, killing my bed lights and upper brake light if I remember correctly. The wire to the bed lights is the thinnest electrical circuit conduit I’ve seen not on a circuit board ! if you add anything to it, that will probably push it to the limit.
I can tell you that 3 amps rated draw is too much, I am not able to say how much you can add without trouble.
good luck !
This is exactly right. The majority of lighting outputs from the BCM are controlled by Field Effect Transistors (FETs). They monitor circuit current, and will set DTCs if the current draw is out of range.
There are multiple thresholds that must be met before the BCM will disable the circuit output. Therefore, you could have a DTC set and there would not be any visual indication of it. Once that DTC continues to be present over a predetermined amount of cycles/time, the BCM will permanently disable the circuit and the BCM will set an internal failure DTC, which requires replacement of the module itself.
The system is not designed for any load in excess of the factory component draw. That includes relays as well. The only time relays can be used is when the relay is replacing the original component, such as when an upfitter removes the factory incandescent lamps on a chassis cab and uses a relay to power LED lamps. The relay substitutes for the load drawn by the factory incandescents. If the LEDs were replaced without using the relay, a DTC would set for the current draw being too low (open circuit).
FordTechOne
Detroit
Yikes! Don't want anything to do with that. I guess Ford ran the minimum wire needed to service all the electrical, probably saved a bazillion by not over-engineering it.
Not just cost save, but weight reduction. Harnesses are a significant contributor to curb weight, which is why wires are sized only for their required load.
Proflyer
Proflyer
Denver
I'll tap into the homerun I have for the Rigid pods in my bumper, and just use the switch it comes with. Easier to do that anyway as getting to the bed light harness is likely a lot more work. Thanks a ton as always @FordTechOne I think we all need your Venmo for some beer $$
