GEN 2 T4ARGHHH Build/Adventure Thread
BSP10
Los Angeles
-Switchpro 9100 installed - factory uplifter switches kept blowing fuses, plus i miss strobing my chaselights LOL
Can you elaborate on the Switchpros? Why look at something like this vs the stock switches? (outside of the fact you need more switches). is the switch pro a better option to run your lights, etc through? More options?
I am out of switches on mine and need to add. but it looks like I should just be running everything through the switchpro if I can, is that correct?
an48customs
an48customs
NV
It's far superior over the factory switches.
-amped for 20a per switch and 35a on 2 of the 6 switches vs Ford's 15a and 10a
-low power mode allows you to run non-DOT lights on a dimmer level for running lights or fogs
-strobe mode for things like chase lights
-you can turn things on and off on an app via bluetooth
-master on/off switch 1 button touch to turn on or off everything if youre running multiple lights
-lights can be powered to ignition or battery via the app
BSP10
Los Angeles
Great thank you so much. Should I also send you the bill as I order one? Hahaha. For real though. Thank you!
an48customs
an48customs
NV
Great Build! Probably my favorite truck on here! How do you like bed slider?
Thanks!! Bedslide is awesome. It doubles as my duty truck so i needed something that could serve me well both during the weekdays and weekends.
-0 rattle even during hard pounding over whoops/jumps
-I have drilled into it and mounted my c02 tank base mount, cooler tie downs, etc. The bedslide itself has quickly adjustable tie-down points as well.
-It holds up to 1000lbs pulled out and i've loaded it with bags of cement to around 950lbs and no issues.
-It can easily accommodate a full sized spare
an48customs
an48customs
NV
Np - its a much cleaner solution, especially if you plan to add more lights as you go. It cleans up the bay pretty well.
Here's a photo of my solution under the hood. Its nothing spectacular but its cleaner than the spaghetti mess I had going on before.
an48customs
an48customs
NV
4/19/21:
Not much update on the build minus I ceramic sprayed the vehicle
Shes been off dirt for a few weeks for once so its nice to see her clean for a bit.
Still waiting on the rear King hydrobumps
