Droid
kglesq's Brother
- Joined
- Sep 25, 2010
- Posts
- 1,486
- Reaction score
- 757
The voice-command button stopped working for a half-hour drive today. When pressed, it would beep twice, then provide no response.
Tried killing motor, pulling key out, opening door at traffic light (to fully reset electronics)...no luck. Tried disconnect/reconnect of my SSD plugged into USB2....no luck.
It finally corrected itself after I arrived at my destination and left it sit for a half hour or so.
I've seen the double-beep when you try and issue a voice command immediately after startup, but normally it will respond if you hit it again five seconds later. (I tend to get in truck and call out a music track immediately.)
No DTCs according to the Nav (i.e., holding 3+6 presets with truck stopped).
Anyone seen this situation before?
