SW exhaust too loud
Hockster
My 45ft Bluewater Party
Winchester, Va
Here is a very easy to follow write up anout how to eliminate exhause drone.
The concept behind drone is pretty simple; nearly everything has a resonant frequency...exhaust systems, electronic RLC circuits, even gravitation has resonance. At peak resonance, the amplitude of the wave at the resonant frequency shoots up to many times higher than normal amplitude. With sound resonance, it pops up when a certain frequency emitted from the engine resonates with the exhaust system and muffler to create that nasty in-cab drone. Unfortunately this resonance often has its peak right in the area where you want to cruise, between 55-75mph.
The solution is a 1/4 wave resonator tube. Simply put, it is a small piece of exhaust pipe with a flat capped end welded nearly perpendicular to the exhaust flow post-muffler that serves to take some of the resonant amplitude and shoot it back into the exhaust pipe out of phase with the resonant frequency to bring down the amplitude. If you've ever taken a physics class, this is in the 'standing wave dynamics' chapter. Mufflers are designed to bring down the amplitude or volume of the exhaust note at all RPMs, but they typically can't do anything about resonance. Corsa mufflers have a built-in resonator that works decent, but only with the entire exhaust kit. Sometimes you'll run across a setup that drones at an RPM the Corsa muffler and exhaust wasn't designed to combat, so theres a chance the internal resonator will do little to no good.
Things you need to know to build the resonator:
-RPM that drone occurs at
-Number of cylinders (engines with simultaneous firing cylinders like the SRT-10 truck will divide this number by two)
You will also need to know the speed of sound. It varies with temperature, but is generally accepted to be 343m/s.
Say your V8 truck resonates at 2000rpms, right at cruising speed. You'll need to find the frequency of the drone. Units here are pulses per second, or Hertz.
f = RPM * pulses/rev * (1/60)
f = 2000 rev/min * 4 pulses/rev * (1/60)
f = 133.34 pulses/second = 133.34Hz
At 2000rpms, your V8 fires 4 times per revolution. RPM is in minutes, so divide by 60 to reduce to seconds. Now you need to find the length of the wave at the frequency you just calculated. Wavelength is denoted by lambda (λ), units are meters.
λ = v/f = speed of sound / frequency
λ = (343m/s)/(133.34Hz)
λ = 2.572 meters
This gives you the length of a full sound wave. The idea here is to reintroduce a sound wave into the exhaust that is 180° out of phase with your drone frequency. To do this, you build your resonator tube at exactly one-fourth the length of the resonant wave. By the time the sound wave enters the resonator tube, bounces off the end and re-enters the exhaust stream, the amplitude is exactly opposite of the drone frequency and will lower or eliminate the volume of the drone.
Dividing the wavelength by 4 gives you 0.643m, or about 2.1 feet. Its long and kind of awkward, but someone who has had to deal with a droning truck on a road trip will likely sacrifice the space to make it fit
The diameter of the tube you'd need is debatable, as I haven't tried different sizes of tubing. When I built mine, I took a shot in the dark and went with 2" pipe on my 3" exhaust. It gives about half the surface area at the end of the tube to bounce off of. I assume a larger resonator tube would allow more sound to bounce back and cancel more of the drone noise. However, space is somewhat limited when you are sending an exhaust pipe off of your existing pipe at some odd angle. You can bend the resonator tube to some extent, but it needs to be mandrel bent, not more than one bend or more than ~30°. If the bend is too sharp, the sound will bounce back too early and the resonator will work poorly or won't work at all.
The reason for this is simply the fact that sound waves do not necessarily 'flow' with whatever medium they are travelling in. Sound is a pressure wave, and any obstacle (bends) will return the wave prematurely. To minimize 'obstables' in the resonator tube, the straighter it is, the better it will work. The intent is not to randomly scatter the sound wave as a radius will tend to do, but to send it back to the exhaust precisely when it is needed.
So, you just need to mock up your resonator tube in a place that it will fit, cut a hole into the exhaust pipe and weld the tube to it and enjoy a drone-free ride.
Sliver Raptor
Charleston SC
SW and Corsa is a good one. just as loud though just sounds cleaner and no drone at all. it does scare people though. I love it!
whiskeybent
whiskeybent
Monfuckintana
I appreciate the responses. I did a search on various manufacturer websites to find a muffler that was roughly the same size and failed to find anything. The next step is to have a muffler shop cut and weld something in. I wish SW had something that was the same size, just toned down a bit. The j-pipe sounds interesting, I just don't think there's much room to fit that with this system.
Anyone know if that particular muffler is reversible (i.e. one way it produces a deeper tone)?
And, yes, I know headers add to the volume of the exhaust... this isn't my first rodeo with headers. My FE390 with LT headers and small(ish) mufflers is much quieter than my Raptor. This setup sounds like I'm running open headers. It's just too much....
M64D RAPTOR
Dothan, AL
Look for "Solo" exhaust. They make a J pipe exhaust I have on my G8 and it got rid of all the drone issues I had.
Netix
Banned
Ontario, Canada
Lol if you think a sw is loud yall should check my straight pipes out . Not only do they pop but my drone on the highway is unbearable together with my mud grapplers. I need ear protection at this point. I pulled up next to a old chevy camaro and at idle mine was more throaty and raspier.
Hell people close their windows now, an i thought my super 10 was loud. Hell no now its x 50
BANE
Michigan
thats because you made the right choice on headers! :)
Stainless Works
Chagrin Falls, OH
Hey guys just wanted to jump in here for a sec. The lightning exhaust setup is truly not for everybody, it can be considered loud since the muffler is located directly under the cab and the tailpipes exit under the passenger side window. Of course it will be noisy, but it does sound like a trophy truck and the tone is very crisp.
Ok, so Stainless Works is listening to our customers. It seems some are happy with the sound some not so much. We originally developed the system using two mufflers instead of our current single muffler with internal x-pipe option. At the time of R&D, our customers said the sound just wasn't right for its intended use. The goal was to design an efficient muffler unique to its application to fit the need of those running aggressive rear suspension setups and with a big boy trophy truck sound. Mission Accomplished!!
After feedback from customers and dealers, it seems we should revisit the two muffler configuration. Customers want the look of the side exit but not the tone. The two muffler setup will bring the tone down and should make it more suited for daily driving but still offering the SW sound. Stay tuned, we are working on this option for the dual muffler setup. Once available we will have a part number to replace the single muffler with two new mufflers as well as an option to buy the whole setup in either the single or dual muffler option.
A.I.I.Raciing
Dezert 8MYMNEY
Costa Mesa
Do you happen to have a sound clip?
Can this be ordered dumped after the muffler?
