BRAPPPP
Not too worried about my bumps getting jacked what ghetto do y'all live in
In my ghetto they just steal your whole f-ing truck!!!
Is Rasco running SVCs FRF account now?
The SVC kit runs a 2.5" King or Fox bump vs Icon 2.0 and the overall size of the kit is virtually identical in size to an RPG kit with the main mounting plates welded to both the inside of the main frame support, plus welded on the entire exterior section as well. I cant think of another kit on the market that does this. The 3 main bolts we supply to attach the can are aircraft grade quality bolts with roughly a 170,000 psi tensile strenght each. The chances of you shearing those off are slim to none. To give you idea the shear capacity of a grade 8 bolt is rated too 27,920 pounds, and the bolts we supply are about 6,000 pounds stronger than that per bolt meaning you have about 18,000 pounds in reserve. A grade 8 would have been strong enough for the application but just don't look as cool. Think of it this way, Raptors have seen 3.0 shocks rip off shock mounts before sheering even a single bolt. Long story short, barring some deffect in all 3 bolts, you will damage a thousand other things on your truck before you could ever blow the cans off the truck.
Also, we changed the production version of the bump kits upper section to add a little more structure vs. the prototype kits, and it wasn't cause it needed it. I really just wanted it to look a little bit cooler.
I'll post up some pics tonight of the production version but for now you can see it in the CAD pics on the ABS page. Those are what the actual production versions look like.
http://www.svcoffroad.com/suspension/svc-adjustable-bump-system
Thanks
Jarrett
