Svc bumpstop kit: kings or fox?
Jordan@Apollo-Optics
aka <b><font color='darkorange'>LSUstang05</font><
The only thing I would be concerned about with SVC, which could also be a positive, is the bumps are bolt on. Any thief could unbolt them and take the bumps. What he would do with them I don't know, but it's a possibility. The advantage to having them bolt on is you could also just remove them completely and leave them at home or inside the truck when you're not going to be offroading. I like the idea behind SVC's design, but living in a big city I'm worried about the bumps getting stolen.
svc
Worldwide
A theif can easily steal the Rpg , icon, and outlaw bumps.
For the Rpg bumps all you would need is a crescent wrench and 3 minutes. Same goes for the outlaw and icon kit. If a theif wants it they will take it. The svc kit is no easier to steal then the rest.
-Jeff
JDUB
Wildomar, CA
The way the svc bolts on doesn't look as beefy as rpg or icon that's what I immediately noticed
Doesn't necessarily need to be as beefy. If you sheer those 2/3 bolts off that hold the bump can and stop on, you are going to have more problems than just a broken bumpstop kit.
If for whatever reason they are sheered off, the bolts can be easily replaced. The other units, like the kit on my truck will bend rather than breaking.
JayneCobb
San Pedro, CA
I just beat the shit out of my new SVC frame support and Fox bumps. Everything held up great and saved me from trashing my truck due to some misjudgements on my part. As far as the original posters question Fox bumps worth the money over Kings? Hard to say. I went with Fox to match the rest of my truck. If I chose King 3.0s over Fox I would have gone with King bumps.
If you get a full 3.0 system King or Fox with bumps its going to be about the same price. My suggestion is to find someone willing to let you drive their truck on and offroad who has a King set up and someone with a Fox set up. TRR might be a good place for that.
Have fun banging your head against the wall trying to figure out which way to go....LOL
-Jeff
Very true. It was just something that jumped out at me immediately as I haven't had any hands on time with other kits either. And the fact that it's just 2 or 3 bolts makes it easy to take them off and store them in the cab if you have to go into a sketchy part of town.
skyscraper
If you are really worried about theft, you can probably find anti theft grade 8 hardware
MajorAR
Kansas
The whole bump adjustment system seems like a good idea in theory, but as human nature has it, we are inherently somewhat lazy and like things of convenience. Probably just me, but I don't see guys adjusting these 6 x bolts/bumps every time you go from an offroad environment back to onroad. (if it were a push button system, then yes).
Possibly a good idea when towing, but "street" setting, seems like a waste, and/or insignificant answer to a problem that doesn't exist.
svc
Worldwide
The SVC kit runs a 2.5" King or Fox bump vs Icon 2.0 and the overall size of the kit is virtually identical in size to an RPG kit with the main mounting plates welded to both the inside of the main frame support, plus welded on the entire exterior section as well. I cant think of another kit on the market that does this. The 3 main bolts we supply to attach the can are aircraft grade quality bolts with roughly a 170,000 psi tensile strenght each. The chances of you shearing those off are slim to none. To give you idea the shear capacity of a grade 8 bolt is rated too 27,920 pounds, and the bolts we supply are about 6,000 pounds stronger than that per bolt meaning you have about 18,000 pounds in reserve. A grade 8 would have been strong enough for the application but just don't look as cool. Think of it this way, Raptors have seen 3.0 shocks rip off shock mounts before sheering even a single bolt. Long story short, barring some deffect in all 3 bolts, you will damage a thousand other things on your truck before you could ever blow the cans off the truck.
Also, we changed the production version of the bump kits upper section to add a little more structure vs. the prototype kits, and it wasn't cause it needed it. I really just wanted it to look a little bit cooler.
I'll post up some pics tonight of the production version but for now you can see it in the CAD pics on the ABS page. Those are what the actual production versions look like.
http://www.svcoffroad.com/suspension/svc-adjustable-bump-system
Thanks
Jarrett
---------- Post added at 12:50 PM ---------- Previous post was at 12:20 PM ----------
I totally agree with some people never moving the cans and that's all well and good because there is no need to if you don't want too. The great thing about the sytem is you can leave them in offroad mode for the whole life of the kit if you want, you won't hurt a thing. The offroad mode is the preffered mode and is the zone that 95% of the owners should leave it in for their everyday use.
My theory is we come in all different shapes and sizes so why not give people who want the option to adjust, the option? The great thing about our kit is the fact we are able to achieve a kit with more versatility than the others for the same cost, performance and strength, and any time I can offer the consumer more for the same as others less, I will do so everytime.
To your point about a problem that doesn't exist, your spot on, it's not a real problem at all. But what I will say about the topic is I have talked to thousands of Raptor owners over the years and I know for a fact many will never use their trucks in the dirt and only want a bump system for the looks of it in the wheel well and nothing more. These discussion are what lead me to add the third comfort zone. We had the room to do it, so why not? The way I see it, if only one SVC customer ever uses the feature then I will sleep better at ninght knowing I was able to put a smile on that customers face.
Thanks
Jarrett
Brendo310
Los Angeles
Beat the shit out of mine as well with the king bumps as you've all see ;)
could not be any happier with the kit!
for me the choice came down to style and i just liked the look of the king bumps! haha
im and equal opportunity consumer! (FOX, KING, DEAVER)
haha
Bottom line... its your truck go with what make you feel warm and fuzzy!
:GetMoney:
