Hey Everyone,
Sorry for the late post, I didn't take any pictures till today, and I wanted to ride it for a few days before posting my first thoughts.
Anyways, Here we go.
Front end: Eibach Springs & SVC TieRods
EIBACH are on the bottom perch for sure, It gives you 3" lift (as their website states) I honestly didn't take any measurements before & after.
The ride feels smoother, no more leaning on turns (like a your in a boat), no more nose dive when braking or going over speed bumps, very steady and feels amazing TBH.
The steering does feel tighter, more controlled, and there is no empty steering wheel space (if you know what I mean), every slight movement of the steering wheels does affect where you're heading.
Back end of the truck: SVC Bump Stop, SVC Shackles (and I already have the +3 Deavers from few months back)
With regards to the rear end, well, I don't think the shackles would have changed the ride feel, however, I do know they are stronger and their bushings are better, but I do like that the squeaking noise I had in the rear of the truck is now gone, smooth.
bear in mind that this orientation of the bump stop is not as it is supposed, the mechanic who installed it seems like forgotten or did it by mistake. the current placement (top 3 holes are used) is for the factory leaf springs, for aftermarket leaf springs the bottom 3 holes must be used. (and in any case that the truck is used for towing/heaving loading, the top 3 wholes must be placed into the lowest 2 holes of the bracket) -this is as per SVC's Instructions).
I will fix the placement later, will share once I do.
All the parts I have installed are top quality in terms of material and build, would recommend them to anyone planning to install them.
and you're wondering, why did I go with king bump stops, that's because I am planning to upgrade to King 3.0s in the future
