Blu Bug
Recently purchase 2013 Roush with 65k on it. I have no idea what maintenance has been done to it. The oil and tranny fluid both look clean. What maintenance should I preform to be on the safe side?
What lube /grease are you using ?Get yourself a spare blower belt. Check the gap on one of your plugs, make sure they are within spec for a s/c engine. Wouldn't hurt to change the fluid in the rear end if it doesn't show signs of being done, don't think the front dif is needed yet. You most likely have a moonroof, put a bit of lube on the track and while you are doing that, add a bit to your pinky and lube the sunvisors where they clip in place, it's a bit ocd, but will stop them from squeaking in the future. Lube all door locks, spare tire key, door latches and tailgate latches, I do this part yearly.
I use food grade axle grease in a tube, just about anything that doesn't liquefy or freeze will work. The sunroof is exposed to high heat and wind chill cold. It doesn't have to be food grade, I just have that laying around because of being in the hvac trade.What lube /grease are you using ?
