Strange Engine Bay Sound on My Gen 2
New recaros
Colorado
Would that indicate a failing alternator?
I was just saying if your alternator is going out, they tend to start making noise before total failure. Maybe every time it goes to full load/charge it starts making noise. The fans others have mentioned may be it.
New recaros
Colorado
It sounds like the cooling fans are running. Which is normal operation.
I agree to fan noise, but why is it cycling. It sounds to me like the fans are in surge, something blocking flow or voltage swings that change fan speeds. Should it not be a constant sound?
FordTechOne
Detroit
I thought that was just the way the recording was picking up the sound, but yes surging wouldn’t be normal.
Def. a fan. Have you been off road? I heard a very, very similar noise in my Raptor Assault truck back in 2017. the fans can collect mud on them, loads them more and creates an out of balance condition.
New recaros
Colorado
Raptors use brushless fans that are variable speed controlled by the PCM.
To me, it sounds like the fans are varying in speed so a tuning or control issue. Maybe the thermocouple wiring or what ever they use to sense temp. If it’s a tunable point, less gain and longer reset. Can you monitor the PCM input and output to the fans?
Enersol
Houston
This is wonderful. Mine 2020 just started doing this same sound right after offroading and going through deep boggy mud. I had quite a bit of mud trapped ontop of the skid plate that I cleaned off but I did not squirt the fans well enough. Mine only makes the sound when its at idle and with this 100 degree temps it does it all the time now. Makes perfect sense now. Thanks for the video.
