Strange clunk from front driver side area
Dane
Dane
Littleton, CO
Most of the "clunks" I have heard come from the lower control arm bolts or the shock mounting bolts. Checked to see if these are all tight.
Will do. Not sure I have the torque specs nor a torque wrench that goes that high, but I can at least identify something too loose and go from there. I suspect the torque setting is about two grunts with my breaker bar. I'll be EXTREMELY disappointed if I find that and the dealership missed it though!
BANE
Michigan
a 2010 came in today with a clunk type nois and it was the passenger side lca bolts
Dane
Dane
Littleton, CO
I'll be examining the bolts tomorrow. Hopefully I find something. I'm pretty irritated about this. Moreso I'm worried that I'll get out into the dunes for a planned trip in July and instantly have a problem which takes me out of commission.
Bigg50
Benicia, CA
My after market upper control arms collar come loose. caused clunking. thought it was the ball joints but only to discover it was loose
Deleted member 12951
Guest
The factory LCA bolt torque is 406lb*ft but I have ICON 3.0's up front. Is that same bolt only 120lb*ft? Big difference, so just wanting to confirm.
Hazzard
Southwest MI
That's what happened to me and it did not affect my alignment at all, I tightened it up and went to the shop figuring it had to be out but nope. It took a min to figure out where the hell it was coming from, I had just replaced my UCA, tie rods, ball joints and coilovers so I knew it was not something wore out.
t_j
Chicago, IL
Correct the bolt for the icon is way smaller and therefore can't be torqued as high. You can try but it will end poorly!
Dane
Dane
Littleton, CO
Well, everything's been checked. Everything is torqued correctly. It's the shock making the noise, which is "normal". So, my two rear shocks constantly chirp and my front driver's side shock clunks loud enough to sound like a balljoint (you can feel it, not just hear it), but the dealer can reproduce the noise and this is normal (even though my passenger side is quiet). And I just get to live with it like that.
@FordService - This sound right? Apparently there's a bulletin, so that makes this all OK.
FordService
...@FordService - This sound right? Apparently there's a bulletin, so that makes this all OK.
Hi Dane,
Let's get your regional customer service manager to weigh in on this. Since we've been in touch before, just PM me a verification of your best daytime phone number, current mileage, and the dealer you've been working with. I'll take it from there.
Crystal
