Stock Replacement Spindle
Yukon Joe
Trafford, PA
What size is the uca pin hole? Is it for a tapered pin or straight?
Also from your earlier answers, I wasn't sure if you guys have dirt miles on these on a raptor or if this is a scaled version of the TT spindle that you have many many miles on.
Yukon Joe
www.RUNRAPTORRUN.com
Rogue Racing
Rogue Racing
Yukon Joe
GREAT LAKES RAPTOR EXCURSIONS
I will get you answers on the technical stuff when I get back into the office on Monday... Just got back from the mint and do not have my tech sheet here...
We do have dirt miles on these and jumps as well on our test track which is also used for testing our LOORS Truck... These spindles are stout and I would not be afraid to take a 20' jump with these... I would be more worried about other items failing than these... These are a mildly scaled down version of our TT spindle...
Rogue Racing
Rogue Racing
Yukon Joe
Yukon,
The UCA Pin Hole is factory sized and is tapered... It is designed to work with a factory UCA or aftermarket UCA that works with a factory spindle...
---------- Post added at 10:12 AM ---------- Previous post was at 10:07 AM ----------
Here you go guys... They are finished, tested, and approved... We will be doing a group buy until Friday...
Sca1pel
Whats the weight on these compared to stock... Since they're a direct oem replacement do I have to get an alignment after if I do a self install?
