Stock Replacement Spindle
Rogue Racing
Rogue Racing
Our Stock Replacement Spindle will bolt right up. Our Stage 4 and Stage 5 front set-ups utilize what is known as a Vertical Upper Control Arm so it will not mate up to the RPG Kit... We will be posting pictures tomorrow of our Stage 2 and Stage 3 Stock Replacement Spindle for you to view... It is pretty gnarly and looks beefy...
Will the stage V bolt up to the RPG stage IV+ setup with dual fronts?
Mjolnir
Colleyville, Texas
Okay, looking forward to it
Rogue Racing
Rogue Racing
The spindles shown in previous post are our Stage 4 and Stage 5... The CAD drawings are from our Stage 2 and Stage 3. We will be posting pictures tomorrow of those. Our Stage 4 does not require grinding so you can return to stock easily. As for travel here are the not exaggerated numbers:
Stage 3 and 4:
Stock Raptor: 11.2"
Stage 3 and 4 Rogue Racing: 12.1"
Stage 5:
Stock Raptor: 11.2"
Stage 5 Rogue Racing: 17.8"
The only way to get more travel would be to widen the track width(+1" or more depending on how wide) or convert to 2WD (+1 or more) and then we can get some pretty stout numbers.
Is this the same design that is used in your stage 3, 4, 5 suspension?
The stage 5 looks pretty sweet, But not sure I want to go with something that requires grinding/welding as I like to be able to return to stock if I really needed to.
Do you know what the usable travel length is in your mid length kits?
Rogue Racing
Rogue Racing
Pictures will be posted on Monday... They are still testing and I have to leave for the day...
