Stock passenger fender liner rubbing turning left
MTUH3
Plymouth, MI
I ran into the same issue. I had a couple retainers work themselves loose. Couple zip ties and new retainers, no issues for the last 2 years.
Dane
Dane
Littleton, CO
That was my first thought - makes sense, but no dice. They all look fine. In addition, in my case, it's limited ONLY to long road trips. I would assume once the retainer worked its way out it would always happen until fixed.
Good thought though. I'm just going to cut that piece of the liner off when I get around to it.
So weird.
MTUH3
Plymouth, MI
I hear you. What I noticed on mine was all the attachments were there, but there was some, though minor looseness.
My hypothesis is that the air pressure on the liner is pushing it back to just under its yield point. Materials like a foam or plastic can often take 24 of more hours to recover. That is why you might only see it on a long trip. Load over time deflects the liner, and takes a while to rebound to its original place
LekRap
Corona, CA
I had the exact same thing happen to me, basically on the first long road trim that I took in the raptor. I thought it was due to my really open front bumper. I just kinda Jerry rigged it for a while but when I went to SVC to have them hammer my pinch welds, I told them about it and they saw the rubbing on the liner. Sean there, was really cool and pulled a perfect condition factory liner from the back and gave me that for free. Also, they secured the liner with some bolts through the front small body price that runs across the front there by the liner. They said its fairly common and it is just the air pressure pushing the liner back and towards the tire. It's a relatively easy fix and nothing to worry about.
