bubblehead93
I have the same springs on the low perch
2010, i did try it and still does the same. my worries are the loose steering it was loose before I changed the rack and pinion last year (it’s cardone remanufactured now) since then it’s have been even more loose and putting all new suspension components didn’t changed anything just better ride quality overall but still play. maybe loose steering shaft? steering bolt? adjust the preload on the rack? i have 120k miles
This:how much play in the steering wheel, i.e. how far does it clock left and right without any movement in the front end. If there is a bunch of play without any rack movement then the problem is either a bad/loose universal joint on the steering shaft or too much lash in the rack... the later can be adjusted with a 27mm allen key/wrench... there are some videos on how to do this on a F150 without removing the rack. Since the steering rack has been replaced, I would look at the locking bolt on the steering shaft universal joint... if loose, you can get a fair amount of steering wheel play...
will do this or next week maybe a change on the rack since I have warrantyThis:
Worth trying even on a reman rack...
what do you mean? too much positive?Rgr on not having the settings, sry, if everything is tight the my guess is your too toe out, positive... Also, what do you run the front tire pressure at...
